DC integration Use Case for Merger of two Companies DC's
VIGUPTA3
H Team,
I am working on an Integration where Customer A has acquired Customer B. They want us to perform DC integration.
Customer B – Using Aryaka SD-WAN
Customer A – Running Meraki Full Stack
They have two DC subnets conflicting and we have suggested NATng on Meraki MX Hub and Create IPSec Tunnels between the Hubs of two DC’s as seen below.
Q1. Can we create S2S IPSec tunnel (Primary and Secondary) from Hub Meraki MX (Firewall) with NATng as shown in below diagram? Currently Full Mesh Topology between sites on Meraki Setup.
Q2. If yes, is there any additional requirement or points to take care if we propose this solution?
Looking for ward for your guidance.
Final State:
Looking for helpful insights.
#Merger #NAT #IPSECTUNNEL
Vishal Gupta
2 Replies 2
Note: This feature is only supported for Auto VPN and is not intended to work with non-Meraki VPN peers.
https://documentation.meraki.com/MX/Site-to-site_VPN/Using_Site-to-site_VPN_Translation
Horrible.  I don't envy you.  I am going to refer to "your" as Company A", and "their" and "them" as "Company B".
I think the best solution (most probable to work and with the most flexibility) will be to get an additional MX and put it into their DC in VPN concentrator mode.  Place it next to their Aryaka SD-WAN box.
Then you can put routes in either SD-WAN pointing to the other SD-WAN.
You could also consider getting them to put an Aryaka SD-WAN box in your DC next to your MX for the most flexibility.
Then you can use the Meraki Site to Site VPN Translation feature linked to by @ww .
