MX Firewall
AlexanderDrago
MX Firewall
Hello!
I create vlans on MX. They work nice, but i have question. I want isolate guest wifi traffic, done it too. But from guest wifi vlan, i can PING gw of another vlan. I trying deny icmp from wifi vlan guest to vlan wifi not guest. Maybe i was wrong anywhere ?
Thank you
AlexanderDrago
Hello!
Everyone, my colleague and me find solution. Use Switch - IPv4 ACL and add rule to close ping
16 Replies 16
Terrence
What I have done is to deny my guest WIFI traffic to other VLANs
Under Wireless, Firewall & traffic shaping
change to the guest SSID
add a layer 3 firewall rule
Policy: deny
Protocol: any
Destination: local LAN
Port: any
Comment: description of rule
CMNO, Dell Certified, A+
AlexanderDrago
Thank you.
I done it, but still have ping from vlan guest to vlan not guest
I use tcpdump and find who answered on my ping request. It was my.meraki.net
Adam
I believe regardless of whatever rules you set up you'll still be able to ping the VLAN gateways.  But you shouldn't be able to ping any devices inside of that subnet if you have the proper rules configured.
AlexanderDrago
Yep, i did rules what close access to hosts in another vlan from guest vlan. But i think its dont right if you can ping gw from another vlans.
Thank you for answered
Adam
I have a similar configuration to yours and I also thought it was strange but it seems to be the design of their product.  In the grand scheme of things, it is relatively low risk being able to ping the Gateways.
AlexanderDrago
Ok i understand, thank you for aswers
GuiCarvalho
Hello AlexanderDrago,
If I understood correctly, you are allowed to ping the GWs of another VLANs, but you can ping another devices of these others vlans? Besides the ping, you can access devices of others VLANs?
If the "problem" is only that you are able to ping the GWs, did you tried to block it in the Security Appliance -> Firewall ->
Security appliance services, putting "None" in the "Allowed remote IPs" box?
GuiCarvalho
AlexanderDrago,
Please disconsider my last phrase. The "Security appliance services" is about services that you can enable or disable to the traffic sourced in the outside interface.
AlexanderDrago
No, i dont allowed ping gw from vlan guest to vlan work. It was came from "box" of router. But i trying to deny ping on gw from vlan guest to vlan work
GuiCarvalho
Alexander,
Take a look at this post. I think that will problably help you:
https://community.meraki.com/t5/Security-SD-WAN/Prevent-inter-VLAN-routing-on-MX/td-p/1437
AlexanderDrago
Ok, thank you i will read this article
AlexanderDrago
@GuiCarvalho wrote:
Alexander,
No, this solution, dont help me with my problem. So how i understand its "new features" in Meraki
Tony_Ang
You can do that by going to Security appliance > Configure > Firewall  then configure it like below.
Let's say your WiFi VLAN is 192.168.0.0/24 and your domain is 10.0.0.0/8.
Choose "Deny" and Protocol "Any" so it will not allow 192.168.0.0/24 client ping or access to any domain IP in this subnet 10.0.0.0/8.
Firewall SettingsFirewall Settings
Alternatively you can do in Wireless > Configure > Firewall & traffic shaping
Wireless FirewallWireless Firewallor this should work too
Wireless > Configure > Access Control
Wireless Access ControlWireless Access Control
AlexanderDrago
Yes, i done it. But ping to gw in another VLan working.
AlexanderDrago
Hello!
CarolineS
Community Manager
Community Manager
@AlexanderDrago wrote:
Hello!
Marking this as the solution on your behalf, @AlexanderDrago. Thanks for updating the community!!
Caroline S | Community Manager, Cisco Meraki
