Event Logs and BGP
Blair
Event Logs and BGP
Hi there,
Can someone explain how we can export Eventlogs out of the dashboard.
It seems to be limited to one page at a time.
Also when is BGP routing going to be available?
You will want to use Syslog if you want to get the event logs into another system - rather than exporting events.
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/Syslog_Server_Over...
I think BGP became available in the 14.x code.  You might have to ask support to enable it for you as well (can't remember, had it enabled a log time ago).  It is not suitable for Internet routing/crciuits.  It is intended to be used internally, such as to a core switch and AutoVPN (basically for route redistribution).
https://documentation.meraki.com/MX-Z/Networks_and_Routing/BGP
2 Replies 2
Blair
Thanks - Is there a filter example for refining the syslog output to see flow rules and traffic matching?
