Hi @Ramtech,
Seems strange.
As MX is L3 and NAT Device. I understand all the downstream devices should use W1 / W2 as per the availability of Link.
I do not see any role for MS / MR out here. They are just L2 (NO NATTING).
The NATTED (Public IP) is for the MS / MR to reach cloud. The devices (endpoints ie. Laptops / Desktops) connected downstream would also work with the similar behavior.
One thought - could you please review Uplink selection & Internet Flow configuration.
- Security & SDWAN > SDWAN & Traffic Shaping > Uplink selection
Also you may consider reviewing the firmware configuration.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
