MX-84 Adding a Second Uplink
leftshot
I'm adding a second ISP so we have a failover for our network.  I see in the documentation where to add the second ISP's configuration information (SD-WAN Uplink). Presumably I need to connect the cable with the signal from the new ISP (which wasn’t stated in the documentation).  I have the following questions that I did not find answers to in the documentation.
1. Does it matter what port we plug into?  It looks like except for Mgmt., the other port operate as a smart switch, but I didn't want to assume.
2. Is there a primary and failover or does it just randomly grab one available uplink?  If there is a primary, how do we specify the primary?
The uplink section simply specifies entries for WAN 1 and WAN 2.  Their documentation says nothing about how these two uplinks are chosen or interact.
3. Anything else I need to do that I have overlooked.
DarrenOC
Hi @leftshot
1. Taken from the following document:
Setting up secondary WAN interface (dual WAN)
The MX84 comes with two dedicated Internet ports, which are both configured through the Uplink configuration under the Local status tab.
https://documentation.meraki.com/MX/MX_Installation_Guides/MX84_Installation_Guide
2. You can set your Primary link under the SD-Wan and Traffic shaping page
Darren O'Connor | uccert.co.uk
5 REPLIES 5
DarrenOC
Hi @leftshot
@leftshot the two ports at the left hand end are hard coded as WAN1 and WAN2 see below:
leftshot
Thanks to both of you.  Exactly what I needed.  Wish they let me choose both posts as the solution.
@leftshot I'm happy with @DarrenOC's post being the solution as he was first 😎
DarrenOC
Thank you @leftshot , best wishes for your deployment
