MX-68 POE+ port
SopheakMang
MX-68 POE+ port
Dear Expert ,
i understand that MX-68 has one port is POE+ ,
Could i use that port to provide Power to Meraki AP  ?
if can , any additional config on that port , or just plug and play ?
KRobert
Yes, You can support the MR AP on that port. I have this setup in multiple locations.
Just enable the port and it is ready to go!
CMNO, CCNA R+S
7 Replies 7
KRobert
CMNO, CCNA R+S
SopheakMang
Dear bro ,
Just to confirm , no extra config right ? , Just turn on the port , then done ?
KRobert
Correct. No extra configurations.
CMNO, CCNA R+S
SopheakMang
Thank so much bro ,
rwiesmann
The MX-68 has 2 POE+ Ports, see Datasheet:
https://meraki.cisco.com/products/appliances/mx68
As I know can you power the Meraki AP's.
See as a sample the datasheet of the MR56 (Power):
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR56_Datasheet#802.11ax.2C_802.11...
rgds
roger
JimmyPhelan
The MX68 with two MR33 or two MR20 is my "Covid 19 CEO At Home, wants WiFi in loads of places" solution of choice.
The inclusion of the PoE ports are a great idea, i would simply love if one on the MX67 had been PoE too. Im not a fan of the MX##W's as the WiFi options are not as comprehensive.
SopheakMang
You are right bro!!!
