MX 64 Unable to fetch configuration
My MX64 Unale to fetch configuration.I tried to restart the device exchange device to restore to factory Settings.But I can't solve it.I saw this in his setup.meraki.com/.I don't have the ability to solve it. I want to see who can solve it
“Make sure you can send outgoing traffic to TCP port 7734 through your firewall”
8 REPLIES 8
Re: MX 64 Unable to fetch configuration
The message means, that there is something upstream, that is blocking tcp\7734. It can be either the ISP router, or another device upstream from the MX, depending on the network topology.
Either make sure that port 7734 is open, or call Your ISP and have them ensure that port 7734 is not being firewalled.
Sometimes, you may need to open a case to support for this problem (provided your uplink doesn't block anything).
But,my other MX64 can be associated with the Meraki cloud at the same ISP
It is my understanding that this issue can only be resolved by Meraki support. Unfortunately I have seen it many times, Meraki know of the problem and are working on a real fix. They have been for sometime now.... still waiting.
Double-check the IP and DNS configuration on the WAN port.
If you put the same configuration on a notebook and plug the Internet circuit directly into the notebook does it work?
The Settings on the WAN port are DHCP.Also try to.Connected with a laptop, you can surf the Internet on a laptop
That's really bad news. Then wait for Meraki's support
I also have the issues "Unable to fetch configuration".
We have multiple M64w running as Teleworker appliance. The issue appears randomly.
An exchange device works perfectly fine at the same ISP. Only remove the device from network an add the new one.
In my cases I let the device sit. After a couple of hours the device get its config and starts working fine.
Since now I had 5 devices with this problem.
Whenever I contact Meraki Support and they reply, the problem is solved.
