MPLS & Internet Links on 2no's - MX450 ?
hianilz
HI All,
MPLS & Internet Links on 2no's - MX450 ? both MX should be in HA
is it possible ? i think it is possible using one access switch and /29 subnet ? can someone how can we connect the cabels from MX's from access switch and vlan's ?
3 REPLIES 3
DarrenOC
Hi @hianilz
Start here:
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
Darren O'Connor | uccert.co.uk
@DarrenOC  thanks for the document I had gone through the document. mysetup slighlty different here, like below.
we have 1 MPLS and 1 DIA circuit
Can MPLS connect WAN1(Internet-1) port of MX450 ? and DIA circuit can be connected in WAN2 ? is that failover works ?
because by default all remote sites should access Intranet services through MPLS link, if MPLS goes down it should failover to DIA circuits ?
is  it workable solution and we need HA redundancy on MX450 also using any Layer-2 switch
Inderdeep
