MG21 with MX68 connection layout
francktls
I have to perform a PoC with a customer next month. Presales ordered MG21 cellular gateway and a MX68 to secure and backup local internet access.
But they ordered only power supply for the MX68.
So I did something to power up the MG21, I use the PoE port 11 on the MX68 to port LAN1 of the MG21. Then I use the 2nd LAN port of the MG to connect the Internet 2Image 29-07-2020 à 12.28.18AM.jpeg interface of the MX68.
It looks like it's working but I think I would prefer a dedicated PSU for the MG. What do you think about that ?
ConnorL
That's actually how my MG at home is configured. Works fine, albeit Vodafone 4G in London isn't great so I only get about 5Mbps. Saves using an extra wall socket!
Jeizzen
For this to work, did you need to create a new vlan that includes port Internet 2 and port 11 ?
Because I think what one of my colleague did once was (with an MS in the setup) :
1 switchport to MG21 poe port
1 switchport to Internet 2 (so Internet 2 not connected directly to MG21)
Those 2 switchports in same vlan
francktls
Hi @Jeizzen
On my config, all ports of MX68 are in same VLAN (Vlan 101 with subnet (Something like 10.10.10.0/24). On MG21, there is another subnet (172.25.25.0/24) with DHCP server. Only Internet 2 is getting an IP on that subnet.
Not sure I properly answered 😊
