Hi all,
wondering if someone has experience with Non-Meraki VPN to AWS....I know I could install a vMX and it would be easy.
But my setup uses Non-Meraki VPN.
AWS seams to have the concept of having 2 Tunnels. So on the Meraki side i configured 2 Non-Meraki VPN peers.
AWS provides to different public IP to do so. This tunnels I terminate on the same MX. VPN status is green for both :).
It also works, but I have some point which i do not understand.
On the AWS side it looks like only one tunnel is active. Is this per design?
On the Meraki side i provided the same subnets to be reachable over the 2 Tunnels on the AWS side.
Does this automatically mean, the traffic will be load shared?
Is it even possible to load share?
One more question is, if I can influence the traffic to use a certain tunnel for an Subnet or even for dedicated traffic?
Has anyone some experience on it? I consulted the Meraki documentation, but did not find any answers on this...or maybe i did not find the right documentation 🙈
rgds
roger
