(Likely) False Positive from Advanced Malware Protection
josephcouture
Not sure if anyone else is seeing this, but we've started getting alerts in from multiple networks that the local MX AMP is flagging an Apple iOS update as malware retrospectively.
File Hash:
6b9a47304497324fe40e3ccfba43bbb056c152500550849d1597fc47b4ebab35 (link)
Download Info:
2020-11-05 11:11 AM PST, by [EDACTED]
File URI / Server IP:
http://updates-http.cdn-apple.com/2020FallFCS/mobileassets/001-62165/F4052D84-DC41-414E-90A4-7E6E971... (17.253.31.202)
Original Disposition:
Unknown
Accepted Solutions
Meraki-MX
Re: (Likely) False Positive from Advanced Malware Protection
We apologize for the inconvenience.
The AMP Research and Efficacy Team (RET) are aware and currently investigating the issue. The immediate issue should be fixed now. The current hash is marked clean.
Thank you.
12 REPLIES 12
Captain_Murphy
I had this pop a few minutes ago. Based upon the URL, I would think it is a false positive as well.
jbright
Ditto. I just saw this same alert from several customer networks.
Bruce
Seeing the same thing here
JW2
Same here.
npoles
Same here.
It looks like there might be another for macOS updates too? I believe Apple pushed iOS, macOS, watchOS, and tvOS last night.
File Hash:42d7434e105150eb67b63c695733710fb552b34de07c93f418814895e4144edd
File URI / Server IP:http://updates-http.cdn-apple.com/2020FallFCS/mobileassets/001-72438/F3289535-A95F-4A79-BE4E-7B78AA5... (17.253.125.204)
Original Disposition:Unknown
Bruce
Talos has labelled one of my files with detection name
W32.42D7434E10-95.SBX.TG
My understanding this is due to a detonation being detected in a Threatgrid Sandbox - probably an automated response. Hopefully the human Talos team will get on top of this soon.  Hoping Apple hasn’t really resorted to pushing malware to take over the world 😀
UCcert
Same here
Darren O'Connor | uccert.co.uk
Dave2000
Same alert here. First odd thing was the alert was coming from one network and the device was located on a different network. The Ip address did not match that network segment. When I created a case the agent said it looks like a legit file, just disable AMP to download it... Wow... Just wow.
nkm
Just received reply from Cisco Rep
Yes, we have been reported that by our client its is Apple's new software update that is causing this alerts it is a false alarm. These alerts are been generated on devices that are on iOS 14.2
Dave2000
My devices are on not 14.2
OS
Version
iOS 13.7
OS Build
17H35
skeenster
Just browsing
Got the same notification by email..  Must be a false positive?
Meraki-MX
Thank you.
