Licensing Roadblock on Z4 Upgrade – Seeking Clarity
CharlieCrackle
I wanted to share an experience I had recently while helping a customer with a hardware upgrade. It’s a bit of a frustrating situation that highlights a few potential gaps in Meraki's licensing process, especially when it comes to newer devices. I’m hoping to get some feedback from the community on how others have navigated this, and maybe someone from Meraki can weigh in on the issue.
The Scenario: Upgrading from Z1 to Z3 (Then Z4)
The customer had two Z1 devices that had failed, (power supplies dying)  and instead of simply logging a support case for a replacement, I suggested they upgrade to the newer Z3 models. The customer still had about two years left on their Z1 licenses, so I was confident we could just transfer those to the Z3s.
However, the order for the Z3s was canceled, and I was notified that they were no longer available. The replacement order was automatically upgraded to Z4s. At first, I thought, "Great, no problem!"—especially since the Z4 comes with some really nice features.
The Upgrade Process
I received the Z4 units, swapped out the Z1 devices, and got the customer up and running. The next step was to make sure their remaining Z1 licenses were updated to cover the new Z4 devices.
Here’s where things got tricky.
The Licensing Roadblock
I logged a case to convert the Z1 licenses to Z4 licenses, but the support agent told me that, according to their Knowledge Base (KB), license conversions like this aren’t allowed. The agent seemed unwilling to escalate the issue or explore other solutions, which left me feeling a bit stuck. I found it odd that a simple hardware upgrade didn’t seem to fit within the licensing framework, especially when the Z3 model (the one I initially ordered) was essentially out of stock and replaced by the Z4.
For those who may want more context, the KB on Meraki’s licensing page lays out how license conversions typically work, but it doesn’t mention the Z4. Meraki Licensing Overview
Is This a Policy Decision or an Oversight?
So, now I’m left wondering: Is this a deliberate policy decision from the Business Unit (BU) to not allow license conversions to the Z4, or is it just an oversight in the Knowledge Base that hasn’t been updated yet? Either way, it feels like a simple upgrade is now stuck in a bit of a loop, with the only solution being to return the Z4s, log a new support case for Z1 replacements, and then wait another two years for the upgrade process to play out.
Looking for Community Feedback
I’m curious if anyone else has encountered a similar issue with the Z4 or if there’s a workaround that I might have missed. Has anyone been able to successfully convert Z1 licenses to Z4, or is this a case where we’ll need to wait for Meraki to update the KB and/or licensing process?
I’d love to hear your thoughts or suggestions on how best to handle this situation. And if anyone from Meraki is reading this, any insight into whether this is something that could be addressed in the near future would be really helpful!
9 Replies 9
DarrenOC
If the hardware has failed then support should have shipped you a replacement. At that point they should migrate the license.  Why have you procured new devices?
CharlieCrackle
Support would ONLY swap for another Z1  so it seem better to get them new hardware... and get them into the 24th century
GreenMan
Meraki Alumni (Retired)
Yes - it would have been like-for-like - unless there was no inventory left of Z1 (which I'd say is quite likely, given the age of Z1), in which case the nearest available equivalent model would be provided (probably Z3) and an appropriate license 'conversion' would be applied by Support.   If I could recommend;   you've made a few assumptions about how things might work - you'd have been better off checking;   initially with Support;   they have strict practices they have to follow.  They don't have any choice.   Secondly with the Meraki account team - if a new purchase was required.  As it's then a commercial discussion, they have a few more levers at their disposal.
This is, unfortunately, where you got tripped up (dam hindsight).  The Z1 doesn't go EOS till July 27, 2025 - so if you had raised a support case, 80% likely they would have swapped it out for a Z4, 20% chance for a Z3.  When an RMA swaps out for a model with a different licence - you get the new licence with it.
How to fix - IMHO - open a support case for the failed Z1s.  Get them swapped out.  Make sure support swaps out the licences (sometimes they forget, so ask for this in the RMA ticket).  Put the replacement Z4s into cold storage for spares.
CharlieCrackle
Good advice !   I did not even know the Z4 had been released...     I just need to do all this before the license expires.    On grace license now.   I was hoping it was just an oversight as I am too much on the bleeding edge...
CharlieCrackle
Was just reading this so it gets even more messy   did not realize there were two different licenses..    ENT and SEC    So I really need a Z1-ENT to Z4-ENT conversion.  (even happy to loose some time in the conversion)
Solved: Z4 and Z3 licenses can be mixed? - The Meraki Community
GreenMan
So...   chances are this is not a permitted 'conversion' from a Support perspective.  If you contact the Meraki account team, they may be able to reflect any residual value of the Z1 license in the pricing for the Z4 license.
CharlieCrackle
Bought the Z4-ENT  but it did not work !!!      Needed to be a Z4-ADV  as the MX was ADV
This is not very clear currently.
TNAComputers
I just found out the hard way that there is a bug in the licensing where the Z4 are not supposed to follow the org highest licensing level. I.e. Your MXs are SD-WAN but your Z4 is ENT. Its supposed to work that way where you can mix and match. However due to this bug, you cant add it with a lower license level and you need to call licensing. They will convert whatever you bought for the Z4 ONLY to whatever your org licensing is until they fix this issue.
