Licence MX84 ENtreprise
sj093
Hello
I would like to renew my Enterprise license
could someone tell me how to do it?
The name of a supplier or their contact ...
7 REPLIES 7
KarstenI
Ask your trusted reseller for a quote. He will be happy to assist you. Where are you located? Here on the community are a couple of resellers that could serve you with this.
sj093
Central Africa Republic
Inderdeep
@sj093 : check if you can locate
https://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do?preferredLanguage=en&preferr...
Regards/Inder
www.thenetworkdna.com
BrandonS
Hi sj093, if you have not already found someone, I am a reseller and have a website you can order from: https://merakinow.com/search?q=lic-ent-mx84 I see you are in Africa and we are United States reseller, but since the licenses are delivered via email this should not be an issue as long as you make payment via one of the provided options.  Best.
sj093
Can you give me a quote? in order to trigger the procedures.
BrandonS
@sj093 I sent you a direct message.
Inderdeep
@sj093 : You need to contact your Meraki supplier for the renew process. The steps I think you already knew about the procedure
https://documentation.meraki.com/General_Administration/Licensing/Meraki_Licensing_-_License_More_De...
Regards/Inder
