- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Future configuration : NAT question, Several uplinks for several vlans
I have a configuration question prior to implementation : I have several IPs (let's say 1.1.1.52/29) and I would like to map several uplinks on each of the available IPs and be able to do port forwarding to internal hosts (which are in different vlans).
I also need that each individual vlan to be mapped to different public IP
Example
Port forwarding
1.1.1.52:3389 -> vlan 1:host1
1.1.1.53:3389 -> Vlan 2:host 1
1.1.1.54:3389 -> vlan 3:host 1
Translation to public IPs :
Vlan 1 -> 1.1.1.52
Vlan2 -> 1.1.1.53
Vlan 3 -> 1.1.1.54
Is there a way to set this up on the Meraki ? I am used to IOS Cisco Routers and never used wan on same subnet.
Thank you.
F.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@FrederiqueC unfortunately MX isn't ideal for what you want as it does not support a subnet or VLAN mapping to a particular external IP. The inbound should work fine though.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
