L7 rules for inbound traffic
victormartins71
Hi everyone,
I know it's possible to activate Layer 7 (L7) outbound rules on a Meraki MX appliance, but I'm wondering if it's also possible to activate L7 inbound rules.
Has anyone managed to configure this?
Additionally, I want to implement geofencing for my incoming traffic.
If I activate the early access NAT Exceptions with Manual Inbound Firewall, it enables NAT Exceptions to be configured per-WAN interface and/or per-VLAN and includes a manual Inbound Firewall table.
However, I only get Layer 3 inbound ruling.
Does anyone know if L7 inbound rules are in the roadmap or if there's any alternate solution?
Thanks in advance!
Brash
I believe it's already been explained above but to attempt to be a bit more succinct, my notes are below.
Inbound L3 firewall rules will block all inbound traffic by default, except for that destined to ports/services available on the MX itself.
L7 Geo-blocking firewall rules do not apply to unsolicited inbound network traffic. It does however apply to inbound and outbound traffic where the flow originated from the LAN.
If you are looking for something to perform more aggressive Geo-blocking, you may need to look at putting a device in front of the MX to perform this task.
14 Replies 14
DarrenOC
Layer 7 rules for inbound traffic is already an available feature especially the GEO part.
Go to:
Security &SD-WAN > Configure > Firewall
Scroll down to Layer 7 Firewall Rules.  Next to Deny you’ll see a scrolly box. At the bottom is Countries
DarrenOC
victormartins71
This is for inbound traffic.
Geographic L7 rules apply both inbound and outbound.
jimmyt234
My understanding is that the L7 Geo only blocks outbound initiated sessions, so whilst it will block inbound attempts to your NAT rules from those countries, it is only doing it because the response from the server gets dropped.
Solved: MX GEO IP filtering on Port Forward rules - The Meraki Community
EDIT: The documentation also states: "The Layer 7 Firewall can be used to block traffic based on the destination country of outbound traffic and the source of return traffic."
MX Firewall Settings - Cisco Meraki Documentation
victormartins71
I have certain L7 countries blocked, but attacks still happen from those very countries.
victormartins71
My objective is to block incoming traffic not outgoing.
A firewall alone does not have the ability to handle all security features, multiple layers are needed. What you want to do cannot be done directly on the firewall; you need to do it on a layer before the firewall.
All incoming traffic is blocked by default. I don't understand what the problem is?
Even if the traffic is blocked, there will always be attempts to access it. Anyone exploiting a vulnerability will usually scan the open ports or even attempt a denial of service.
If you don't want these requests to reach your firewall, you need to hire an anti-DDoS service from your ISP.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Firewall_Settings
victormartins71
On the same document:
The remote IPs cannot be blocked inbound for L2TP VPN or AnyConnect VPN.
victormartins71
That could be a solution.
And since I've seen some attempts on the 443 port to connect to our client VPN, I should look at another VPN concentrator and forgo any Anyconnect Client VPN.
Mloraditch
If you need geo blocking for RA VPN, Cisco has added it to Firepower recently.
See here https://www.cisco.com/c/en/us/td/docs/security/secure-firewall/release-notes/threat-defense/770/thre...
You could get a small firepower unit and retain Secure Client.
Brash
