It's posible migrate the configuraion Firewall Soniwall to Meraki Sonicwall
Mike76
I wan to know if it;s easy migrate Sonicwall to Meraki Firewall
Mike76
6 Replies 6
No, you need to analyze the existing configuration on the Sonicwall and manually configure it on the MX.
Mike76
Thanks, do you know where can I see  a guide to setup a Firewall Meraki?
You can find all documentation on the Marki website.
https://documentation.meraki.com/MX
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Addressing_and_VLANs
https://documentation.meraki.com/MS/Layer_3_Switching/Configuring_ACLs
DarrenOC
As already mentioned it’s not a swift process nor are there any migration tools.
id take the time and effort to document and review the current rulesets. Tidy up where required.
then it’ll be a manual process to configure your new Meraki fw.
BlakeRichardson
Meraki doesn't offer a migration service like some other vendors do, I suspect the reason is MX are quite a bit different in the way they are managed compared to other brands.
My suggestion would be to plan the migration out in stages i.e. research/planning/ initial config/ changeover/tidy up/  debrief. This thigns always involve downtime but this can be reduced with good planning and execution.
Mike76
