Issue with Meraki Dashboard – Uplink Traffic and Live Data Not Visible
Shubh3738
Is there any ongoing issue with the Meraki Dashboard?
Currently, I am unable to view Uplink Traffic and Live Data.
Boomerang94
Further update on this:
This behavior was observed on a limited subset of backend servers, resulting in issues affecting specific networks. Our backend team has already deployed a fix, and we are now seeing normal functionality restored across the majority of impacted networks.
If you continue to experience any issues with the live tool, please contact Meraki Support by opening a support case, and we will be happy to assist you further.
.ılı.ılı. Cisco Meraki
Network Support Engineer
### If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it ###
Boomerang94
Hi Shubh,
This is a known issue that our DEV ENG team is currently investigating, please bear with us at the moment while we get this fixed for you.
I can see you have already raised a support ticket with us. We will update you via the same thread.
TVarias
We are having the same issue.  None of our Uplink Traffic Live Data is functioning in any of our dashboards.
Showing fine on shard 199, what shard are you on?
Boomerang94
