Trying to narrow down what EUD attempted to access the site.The event log only shows the AP they are connected to that hit the site but no client info.
Solved! Go to solution.
You would need to use bridge mode on the ssid. Or a syslog server that collects all mr flows to find it.
Simple enough answer. Thank you, I will have to look into that
