Integrated Cellular issue with Free ISP (France)
dimatt
My MX with integrated cellular still in connecting status with Free ISP (French operator).
When i try with another SIM Card from another provider (Vodaphone) it works.
The Free SIM Card works in a mobile phone.
The Free ISP don't use the same frequency than Vodaphone, perhaps it's the clue.
Do you have any idea ?
10 Replies 10
And the mx device cellular modem support that frequency?
dimatt
I don't know,
Free 5G frequency are 700 and 3500 Mhz
Vodaphone frequency is 2100 Mhz
Meraki does not have any mx with 5g support. I believe the build in cellular is similar to a mg21
dimatt
ok, i didn't know for the 5G. I took a look to the documentation, you are right.
For 4G frequency:
Vodaphone use 800,1800,2100 and 2600
Free use 700,1800,2100,2600
dimatt
it's an MX68CW-WW
dimatt
For 4G frequency:
dimatt
Also note that sometimes you have to forcibly configure the APN on the MX (under the uplink tab).
You would need to ask the carrier what APN you should be using.
dimatt
I tried with the APN name, same thing.
lucasmajxr
Bonjour,
Mon MX avec la carte SIM cellulaire intégrée reste en « connecting » avec l’opérateur Free. Avec une autre SIM (Vodafone), ça fonctionne. La SIM Free fonctionne sur un téléphone portable. Free utilise peut-être des fréquences différentes de Vodafone, ce qui pourrait lizaro casino https://www.villeinitalia.fr/casino/lizaro/ expliquer le problème. Il se peut que le module cellulaire du MX ne supporte pas certaines bandes de Free. Avez-vous des idées pour résoudre ce souci ?
