Site to site VPN overlapping subnets
Jayt1
Hi
Migrating to Meraki.  I have a non Meraki firewalls.  Migrating to MX-85's for 22 remote offices.
I currently have 1 VPN configured. I use the same subnets to each location to allow connection to home office resources.
I attempted to add another VPN & got the message that I have overlapping subnets.
I will need to have each VPN connect to the same networks. From what I read, I need to create NAT's for each subnet? That would seem to be very complex since I need over 100 for that to work. Is there another way to do this?
Mloraditch
It sounds like you are trying to connect the 22 remote offices via Third Party VPN to your headquarters that does not have Meraki. Is that correct?
If so you don't need to create separate tunnels on the Meraki side for each VPN. The Third party vpn settings are shared by all MXs (or all MXs with the appropriate network tag). On your non meraki head end you would need to make sure the encryption and key settings are the same for every remote site that has been switched to Meraki.
10 Replies 10
RWelch
If possible, assign unique subnets to each remote site to simplify VPN configuration.
If you must use overlapping subnets, configure VPN subnet translation (NAT) for each site.
There is no alternative built-in method to avoid this complexity if you must connect multiple sites with overlapping subnets. The best practice is to ensure each site uses a unique subnet, but if that's not possible, VPN subnet translation is the supported solution.
Note: VPN subnet translation (NAT) is only available for Meraki Auto VPN peers and is not supported for IPsec VPN peers. To ensure successful VPN connectivity, each site must use a unique subnet. If overlapping subnets cannot be avoided, you will need to redesign your addressing scheme or use external NAT solutions outside of Meraki.
Jayt1
So...
Example
My core office has a data subnet of 172.16.1.0.
I need to have 22 remote sites connect to this subnet.
Each site has it's own local subnet that is not the same.
Remote site 1 is configured.
I try to configure remote site 2 & then I get the duplicate subnet because I already have the 172.16.1.0 network going to remote site 1.
Then do I need a NAT for the 172.16.1.0?
Mloraditch
@Jayt1 if your LAN subnets are all different then you should not have any problem.  Please share a screenshot of where you are seeing the message (redacted if needed).  Or do each of your remote sites all have the same subnet?
Jayt1
This is what I get...
"The settings you requested require confirmation. Please review the following list.
The VLAN subnet 0.0.0.0/29 overlaps with remote VPN subnets on non-Meraki peers Fortigate (0.0.0.0/24) and Fortigate Secondary (0.0.0.0/24). IP traffic will be routed to the smallest subnet that contains the IP address.
In the non-Meraki VPN peers configuration, potential overlaps might occur between the subnets on Fortigate (10.1.0.0/24, 10.1.0.0/23, 10.1.20.0/24, and 10.1.20.0/25). Please note that in this case, IP traffic will be routed to the most specific subnet.
To learn more, please refer to the Peer Availability section of the Site-to-site VPN Settings knowledge base article (accessible through the non-Meraki VPN peers tooltip)."
Yes the home office is a Fortigate. However not all remote offices will get all of the same access. I have 1 site configured on a MX450 that is in another location back to the same Fortigate.  That is working fine.  I assigned that a network tag & have tags for the other mx-85's
I have a ticket in to see what's up.
Do you have a 0.0.0.0/29 subnet or a 0.0.0.0/24 subnet configured anywhere as that looks somewhat odd to me?
Are you using AutoVPN?
Jayt
Each remote office doesn't have the same subnet.  However I need to pass the same subnet from the home office to each of the remote sites.  Here's a pic & what I need to doIPSEC Example.jpg....
What make of firewall is at each site?  I'm the first post you say you have non Meraki firewalls and that you have MX85s.
Jayt1
Support said I have to use 1 big tunnel instead of trying to set up 22 of them.  The overlaps are voice vlans so our antiquated phone system can inter office 4 digit dial the 22 offices...That isn't going to work with the Meraki MX/Fortigate. Until I swap the Fortigate out which will be in 6 months.
