Search instead for
IDS/IPS
IDS/IPS
I want to confirm if our Marki MX 13.28 has the capability of IDS (intrusion detection system and IPS (Intrusion protection system)
7 REPLIES 7
Re: IDS/IPS
Yes, if you have an Advanced license on it. No, if you have an Enterprise license.
Re: IDS/IPS
how can check which license I have?
Head in the Cloud ww
Re: IDS/IPS
organization 》 license info
Re: IDS/IPS
I do not have organization as a choice
Re: IDS/IPS
Under "Security Appliance" do you have the "Threat Protection" Option? If not then you're Enterprise.
Re: IDS/IPS
I have enterprise easy to switch or need another device
Re: IDS/IPS
Not easy to switch but you'll want to work with your sales rep to get that figured out.  To see if the existing license can possibly be returned to purchase the desired license.
