IDS/IPS
Frank1
IDS/IPS
I want to confirm if our Marki MX 13.28 has the capability of IDS (intrusion detection system and IPS (Intrusion protection system)
7 Replies 7
jdsilva
Yes, if you have an Advanced license on it. No, if you have an Enterprise license.
Frank1
how can check which license I have?
organization 》 license info
Frank1
I do not have organization as a choice
jdsilva
Under "Security Appliance" do you have the "Threat Protection" Option? If not then you're Enterprise.
Frank1
I have enterprise easy to switch or need another device
Adam
Not easy to switch but you'll want to work with your sales rep to get that figured out.  To see if the existing license can possibly be returned to purchase the desired license.
