HIDE PUBLIC IP ADDRESS ON NETWORK USERS
Prince
Hi Everyone,
Just want to ask if there is a way to block/hide our public IP address (ISP IP address) from the users of our network?  By searching "what's my IP?", there are sites that could identify our public IP.  Using a speedtest also shows our IP address.  We sometimes had guests that connect to our network.
My concern is that if they know our Public IP they could leak this information intentionally or unintentionally and could be used for cyber attacks.
Thanks in advance.
6 Replies 6
ConnorL
Meraki Employee All-Star
The only way to "mask" your public IP would be to tunnel all your traffic to another endpoint, either by utilising an AutoVPN or Non-Meraki VPN connection to another node, or a third-party solution such as Umbrella SIG or ZScaler SWG
The public IP shown would then be that of the exit node of said tunnel/end-point, rather than the IP of your MX/router. Note you'll likely have a reduced overall throughput due to the overhead of a VPN connection.
TyShawn
Silly question but what information could be leaked by knowing your public IP?
MartinS
Not a fan of 'security by obscurity' here - I would suggest that if knowing a public IP causes you a security problem, you need to address that security problem
COO
Highlight - Service Observability Platform
www.highlight.net
GreenMan
Have to say;   I'm with MartinS on this;   the bad guys will find you, wherever you are;   key is to make sure your door is locked and bolted.
double_virgule
I agree with everyone here, with one caveat: There is a reason that the TOR browser exists. It masks your traffic by throwing it out a bunch of different endpoints at random.
The use case that this user is describing specifically (their users looking up their public IP and sharing it with a threat actor) would not be prevented by changing or masking the public IP, but if they have a specific need to prevent the traffic they are shipping from being associated with a specific IP, that would be a different conversation.
@Prince - Your users will always be able to see their public IP through some means, no matter what content filtering or masking you put in place.
