Getting error while creating a group policy on MX 64
Anukul_Tiwari
Any idea what can be reason for this?
7 Replies 7
The error suggests that you have a configuration error in Site to Site VPN.
Can you share this configuration?
Anukul_Tiwari
The error is saying one of those hubs is invalid.  Are they all correct?
Are all 3 HUBs valid?
Anukul_Tiwari
I think than I fixed it before screenshot sent to you, there was a 4th entry which was not active anymore, I removed it, will try once again creating the group policy thanks for help!
Great. 🙂
RaphaelL
I know the solution is simple : remove the "dormant" or inactive Hub(s) , but these dashboard checks are way out of control.
Can't configure a group policy because you have a offline vpn concentrator ? Makes 0 sense.
Can't configure a DHCP ip-helper if the IP is not in the routing table ...
Can't configure a syslog server if the IP is not in the routing table ...
That's not really ZTP friendly.
My yearly rant is done 😁
