Gateway in other VLAN pingable
braham2019
I have firewalled off a VLAN behind an MX65 and have create a FW rule to block ALL traffic from that VLAN to the other 3.
I cannot ping a host in the other networks. However, I can ping all the default gateways from those networks. Is that normal behaviour ?
1 Reply 1
NolanHerring
Yes that is normal, however I wish by default it would also block pings. I believe you have to create a specific ACL to also block ICMP, based on these other threads.
https://community.meraki.com/t5/Security-SD-WAN/How-to-segregate-VLANS/m-p/32991
https://community.meraki.com/t5/Security-SD-WAN/Prevent-inter-VLAN-routing-on-MX/m-p/1437
https://community.meraki.com/t5/Security-SD-WAN/MX-Firewall/td-p/20426
Nolan Herring | nolanwifi.com
TwitterLinkedIn
