Routing internal traffic out to a specific public IP - MX65
IanDonald
Hi All,
First time poster.
I have 2 ISPs.
ISP1/WAN1 - 1 Public IP
ISP2/WAN2 - 5 Public IPs
Is it possible to route outgoing traffic using WAN2 with a specific public IP address?
Would like to separate guest wifi and exchange server traffic to use a specific public IP address on WAN2.
Ian
Accepted Solutions
theshmike
Re: Routing internal traffic out to a specific public IP - MX65
I had the same question a few months ago, and I've found out, that the MX cannot do that.
The MX always SNATs with the address of the uplink.
On Sophos gear, the feature is called "masking", but Meraki can only do incoming NAT with multiple addresses
No clue what the folks at Meraki thought by not implementing such an essential feature 😉
5 REPLIES 5
nealgs
check out this thread Ian
https://community.meraki.com/t5/Security-SD-WAN/Meraki-mx64-with-two-Internet-connections/td-p/22295
similar question on an MX64, but should apply the same
hope this is useful
IanDonald
Thanks for the link nealgs
I have managed to setup the second WAN/ISP fine. I have rules in place to route inbound traffic using the public IP addresses fine using 1:Many NAT. Just can’t find anywhere to allow me to direct outbound traffic with a specific public IP address.
Under SD-WAN & traffic shaping we can use Flow preferences to use a preferred uplink only (WAN 1 or WAN 2), not a public IP address.
jdsilva
The 1:1 NAT is the only option. You can't, for example, SNAT an entire subnet to one IP outbound.
theshmike
IanDonald
Thanks for the info. I have came to the same conclusion.
To me such a basic feature missing.
