Firewall Rules (L3) - Rules not Applying
pBrain
Am I missing something?
I set up this rule:
# 2
Action: DENY
Protocol: ICMPv4
Source: ANY
Port: ANY
Dest: IOT NETWORK
Port: ANY
Why am I still about to ping devices in my IOT Network?  Am I missing something here?
Did you keep the ping running or  wait for  5+ minutes?
Are you pinging the device  or the svi?
5 REPLIES 5
CptnCrnch
Any Group Policies in place?
pBrain
Yes, but those are specifically set to follow the Network Firewall Rules.
pBrain
Kept pinging.  I am going to stop it and try the ping again in 10 minutes (for good measure).
I am pinging the device directly from another device on a different VLAN (not the dashboard).
MilesMeraki
Does the configuration status of the MX show up to date? If not it'll be because the configuration hasn't yet been applied.
If not try and stop the session and try again once the configuration status shows up to date.
