Search instead for
Filter traffic in Autovpn
Once estabilshed an autovpn network is it possible to filter traffic? For example I want let communicate voice vlan only to other voice vlan and on sip port of the other network or filter traffic so clients can connect to domain controllers only on necessary ports
Is it possible ?
I tried with outbound rules of vpn or firewall layer 3 but it's not working
Just to explain the network schema I have a network with 5 vlan. My MX has 1 only ip address and it can see the other vlan with a static routing to internal default gateway
Accepted Solutions
Re: Filter traffic in Autovpn
Yes it is, it's the outbound rules in Security & SD-WAN > Configure > Site-to-site VPN. Don't use the inbound rules, they've been added by accident.
More info here:
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
1 REPLY 1
More info here:
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
