Error Policy must be '0' or '1' when configuring port forwarding rule
francktls
Hi Community,
Got an error that I never seen before when I'm configuring a port forwarding rule on a MX.
Simple rule :
Description : voice
Uplink : Internet2
Protocol : TCP
Public Port : 11443
LAN IP : 172.20.100.4
Local port : 443
Allowed remote IPs : Any
Error :
There were errors in saving this configuration:
  • Policy must be '0' or '1'
I don't use policies in this org...
Somebody has an idea ?
Many thanks,
Franck.
6 Replies 6
Are you trying to create port forwarding rule? The configuration looks fine. Are you configuring another rule (such as the L3 rule) at the same time?
Also, can you show the firewall configuration page?
francktls
of course, nothing interesting...
Well, It looks like a bug, so my suggestion is to open a support case.
Ryan_Miles
On the traffic shaping page do you have any flow preferences or uplink selection rules set?
JonM18
Ran into the same issue. Having a flow preference on the same subnet was causing the issue. Had to remove the flow preference to resolve.
@Ryan_Miles The "Policy must be '0' or '1'" error text could be improved! 🙂
