Dot1Q trunk is possible on Passthrough Mode?
thi4go_p
Just browsing
I've some doubts about Meraki MX behavior while in Passthrough mode. I want to know if is possible connect the MX between a core switch and a router that have dot1q enabled (multiple vlans) in passthrough mode.
Switch (trunk) -----> Meraki MX (passthrough) -----> Router (with sub-interfaces)
I see on Cisco page inform that VLANs aren't supported, but I don't want configure it on MX, only on the end points (Switch and Router).
Thanks,
Thiago
yes this works. it does not edit the packets/vlan tags .
1 Reply 1
