Difference between running BGP and Default route with ISP
Naresh_Bhardwaj
Hi ALl,
Want to know the Difference between running BGP and Default route with ISP and  which one is better.
Bruce
For one or two internet links to one site with limited inbound requirements, the best option is a default route, it’s simple and straightforward - and it’s really the only option you have with a Meraki MX. The BGP configuration on a Meraki MX is for a head-end concentrator to exchange routes with the data centre core for a SD-WAN style solution, it’s not for ISP connectivity.
If you’re looking at more complex solutions where you host your own public IP addresses, or failover between multiple links or even multiple sites for your internet then you may need BGP, in which case you’ll have to put a BGP capable device (e.g. a Cisco router) at the end of the ISP links and design the network appropriately.
Naresh_Bhardwaj
@Bruce
What is not using MX. I will use Cisco ISR router with Provider.
Claes_Karlsson
First of all, this is a big design question that is difficult to answer in a forum post.
How do you mean running BGP?
Would you like to pick up global routing table to your devices and then route/filter traffic on your own and peer with ISP where you own your AS number and IP-addresses, or would you like to just peer with the ISP and advertise your IP-address subnet/AS  and let them do the routing/filtering?
There is a lot of cons that come with handling all the routing yourself. You have to take security in consideration, regarding denial of service attacks etc. Running full BGP on your devices also demands attention and configuration updates if you want it to run smooth.
For the most of the cases, it's enough to just peer with the ISP, advertise your subnet and receive an default route from the ISP if you have some need or requirements to run BGP (your own AS/subnet).
Make sure your devices is able to run full BGP if the design requires it. Otherwise, talk to the ISP and let them advertise your public IP subnet and just receive default route.
