Cradle Point Wireless WAN2 - Is it possible to limit to certain vlans or hosts
mthor
Good morning,
I have a cradle point for a wireless backup in the event our primary link goes down. Is it possible to limit this particular uplink to only supply internet to particular IP addresses or vlans if the primary goes down? I can't seem to find a way on our MX to do this, so I am wondering if this is possible or if someone can point me in the right direction.
Thank you
PFSMatt
I believe Support can change WAN2 so it's treated as a cellular connection, and thus will follow the usual cellular-only rules.  Haven't used it myself to say for sure, though.
6 Replies 6
CptnCrnch
Cellular-capable MX devices like MX67C have the ability to run Cellular-only firewall rules. I dont's think there's another solution for 3rd party LTE backup.
mthor
Thank you for the quick response.
PFSMatt
mthor
Thank you for your quick response. I will contact support and see if they can do this.
Ryan_Miles
Yes, Support can enable that.
mthor
Support made the change. Thanks for this.
