Connection from internal LAN IP
WarrenG
We are trying to reach a system on our internal network that will only accept connections from an internal IP address on the same subnet. Is there a way to make the Meraki firewall present a connection request from outside the network as if it's coming from an internal IP address?
Bo_Tang
Perhaps not,  both port forwarding and 1:1NAT won't change source IP;
I think you may consider using Client VPN to assign the client with internal private IPs to enable them to access your internal server anywhere.
Bo_Tang
WarrenG
Thanks Bo_Tang, this actually worked! I didn't think it would as the client VPN has it's own different subnet. But hey I'll take the W!
Thanks again!
You can use a client VPN, and Anyconnect is the best option:
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance
