- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How to define client VPN routes with MX250
We have users who should have different permissions. You could divide the users into different groups.
Administrators should be able to access everything.
A group may access certain servers.
Another group can only access certain ports of servers on all Site2Site VPN (AutoVPN).
The authorization for the ClientVPN takes place with RADIUS on the ActiveDirectory server https://documentation.meraki.com/MX/Client_VPN/Configuring_RADIUS_Authentication_with_Client_VPN. But according to the instructions I don't get any routing to a network from the client at all and I don't want to change any default route on the client. I can't set the routing to all known networks anywhere.
I try to use Windows 11.
Regards, Ronny
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The best option if you intend to limit access is to use Anyconnect and configure group policies with Filter-ID.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance#Server_Settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
