Connecting Nighthawk M2 to MX Internet WAN Port
SCC
Hi All,
Due to the bad reception in the server room , I can not use the LTE option. So what i was thinking is to connect the Telstra Nightawk via the patch panel and keep this Nighthawk to a place where i will get the good reception and connect all the way via the patch panels or internal cabling to the Internet port of MX.
Will this work ? are there any internet drop issue with respect to MX and Nighthawk connecting to the Internet port of the MX.
Pls advice...
https://www.telstra.com.au/internet/mobile-broadband/nighthawk-m2
2 REPLIES 2
AjitKumar
Hi
I understand this should work smoothly. As long as M2 has proper internet I do not see a challenge.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
SCC
Thank You. This is great.
