PhilipDAth,
Thanks for the link. I'm using the VPN setup script and it is working great.
Questions:
1) If I use Meraki cloud authentication do I need the -DNSSuffix "[insert domain name]"? What is this for?
2) Meraki's documentation says to select "Require encryption (disconnect if server declines). Your script uses
-EncryptionLevel Optional. If I change it to -EncryptionLevel Required, I get an error saying / The current encryption selection requires EAP or MS-CHAPv2 logon security methods. PAP and CHAP do not support
Encryption settings 'Required' or 'Maximum'. : The parameter is incorrect.
Should I be worried about using the Optional encryption level?
Thanks, Jon1
