Hey Gurus,
Installed a new POS system for a client. 100% Meraki MX, switches, and wireless. All POS devices are hard plugged directly into the Meraki switch (home runs) on the POS VLAN.
Customer called that POS terminals are having an issue. I login to Meraki and can ping all POS units with 0% packet loss, however when I check the event log I am seeing an IP Conflict. We reboot the POS units and the issue stops and the client IP conflict goes away. Randomly it starts again and the client IP conflict comes back, so I know for certain when client IP conflict happens the POS have issues.
POS
Things we have tried:
- Removed dumb switch between Meraki & POS and ran dedicated home runs back to Meraki switch
- Used DHCP reservations, then removed them
- Turned off Meraki firewall IP Spoofing
- Upgraded firmware of switch and MX
- Ran cable tests on switch, confirmed no issues with drops
I called the POS vendor who said they want us to install the Zyxel router that came with the system. Frustrated they are making us do that because system requires no porting forwarding and only needs a specific VLAN with DHCP that is all. We are doing that now but want to see if anyone has seen this before and if they were able to fix it.
