Client VPN Issue
nmemmert
Client VPN Issue
I have user that is configured to connect on client VPN...I have verified that all his setting are correct but he is still not able to connect. We are using MS NPS for authentication but there NPS server does not show him in the logs all I see are the following from the Meraki logs... anyone have any thoughts?
May 7 09:06:59
Non-Meraki / Client VPN negotiation
msg: failed to begin ipsec sa negotiation.
May 7 09:06:59
msg: no configuration found for 184.170.72.175.
May 7 09:06:59
msg: ISAKMP-SA deleted 216.98.75.115[4500]-184.170.72.175[4500] spi:495cbc08da3d1d16:d793b6511aa6171c
May 7 09:06:59
msg: ISAKMP-SA expired 216.98.75.115[4500]-184.170.72.175[4500] spi:495cbc08da3d1d16:d793b6511aa6171c
May 7 09:06:59
msg: purged IPsec-SA proto_id=ESP spi=150744868.
May 7 09:06:57
msg: IPsec-SA established: ESP/Transport 216.98.75.115[4500]->184.170.72.175[4500] spi=150744868(0x8fc2f24)
May 7 09:06:57
msg: IPsec-SA established: ESP/Transport 216.98.75.115[4500]->184.170.72.175[4500] spi=54281960(0x33c46e8)
May 7 09:06:56
msg: ISAKMP-SA established 216.98.75.115[4500]-184.170.72.175[4500] spi:495cbc08da3d1d16:d793b6511aa6171c
May 7 09:04:25
msg: IPsec-SA expired: ESP/Transport 216.98.75.115[500]->184.170.72.175[500]
3 REPLIES 3
Inderdeep
@nmemmert : Hope you followed this
https://documentation.meraki.com/MX/Client_VPN/Configuring_RADIUS_Authentication_with_Client_VPN
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
Make the problem simpler to see where the issue is.
If you change to using Meraki Authentication - can you make it work?
If this is a Windows client, you can try creating a script using my tool to help eliminate user errors with configuration.
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
This is for a Mac client. I have the VPN working for Windows, Mac and Linux but for some reason it is just this one client this is not working.
