We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hi All,
I'm looking for some documentation or your inputs on SIEM integration with Meraki MX products.
Is there any specific requirements? is it possible ? anyone using it?
Regards
BS
Solved! Go to solution.
Well not many options to choose from, but I just figured the wireless event log for example is probably not relevant to what he is looking for. 😃
IMO I wouldn't filter the Syslog form the MX. All that flow data can be ingested by a SIEM as well. If it was me I'd send everything available.
@NolanHerring Wireless logs aren't available from an MX. You must be looking at a combined network 🙂
