Cisco Meraki MX Integration with SIEM
Hi All,
I'm looking for some documentation or your inputs on SIEM integration with Meraki MX products.
Is there any specific requirements? is it possible ?  anyone using it?
Regards
BS
Accepted Solutions
Re: Cisco Meraki MX Integration with SIEM
Well not many options to choose from, but I just figured the wireless event log for example is probably not relevant to what he is looking for.  😃
Nolan Herring | nolanwifi.com
TwitterLinkedIn
7 REPLIES 7
The only thing I know of is using syslog for security/IDS events to a 3rd party SIEM collector.
TwitterLinkedIn
Thanks Nolan
Is it just pointing to the SIEM IP address?
Far as I know yes, just the IP address via syslog option. Just filter the syslog to only send IDS
TwitterLinkedIn
IMO I wouldn't filter the Syslog form the MX. All that flow data can be ingested by a SIEM as well. If it was me I'd send everything available.
TwitterLinkedIn
@NolanHerring Wireless logs aren't available from an MX. You must be looking at a combined network 🙂
Oh I am. Good point 😃
TwitterLinkedIn
