Hi All,
I'm looking for some documentation or your inputs on SIEM integration with Meraki MX products.
Is there any specific requirements? is it possible ? anyone using it?
Regards
BS
Solved! Go to solution.
Well not many options to choose from, but I just figured the wireless event log for example is probably not relevant to what he is looking for. 😃
IMO I wouldn't filter the Syslog form the MX. All that flow data can be ingested by a SIEM as well. If it was me I'd send everything available.
@NolanHerring Wireless logs aren't available from an MX. You must be looking at a combined network 🙂
