I have a client with full stack Meraki that has a requirement to share their SM fiber internet handoff with another business unit that wishes to use their own separate firewall with a direct, public IP.  My first thought is the only way to do this is with a "breakout switch" in between the fiber handoff the rest of the gear or do it using available ports on their switch stack in a common VLAN.
So, I might get 2 new SMF SFP modules and put them in SFP on a switch and create a common VLAN with those two ports and a third copper port (for the other business handoff). Then I can patch the internet handoff fiber to one of those ports and the other fiber port back to the WAN port of the MX.  I would keep the IP I have for the MX and let the other folks use an available one from the block and patch into the copper port on that common VLAN.
Is there another or better way to do this I am not thinking of?
