Blocked ports
MerakiCrazy31
Blocked ports
I have a customer that wants to lock down all outgoing traffic and only allow through required ports. However, how can we see the traffic that is being blocked? I don't see anything in the event logs? I just see the figure by the "deny" rule going up
Raj66
Hi @MerakiCrazy31 You can leverage syslog to get this information. More information in the below documents
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/Syslog_Server_Over...
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
1 Reply 1
Raj66
Cheers!
Raj
