I need to have historical bandwidth usage data for both WAN link of MX.
How can i get actual usage without averaging .
(What we are getting is Averaging bandwidth consumption data ,which changes as we change the time duration.)
Any help.
Solved! Go to solution.
Two available options are querying the MX with SNMP or send NetFlow data to your collector.
Thanks Karstenl
we don not have any SNMP and collector tool...can you please help in suggesting any open source option either for SNMP or Collector tool?
Netflow:
https://www.pcwdld.com/free-open-source-netflow-analyzers
For SNMP I can recommend CheckMK, there is on open version but also a commercial product that is free for up to 25 devices.
https://checkmk.com/product/editions
Can you see what link the data is on using netflow? Wan1 or wan2
Yes on realtime basis
