SAML SSO with adfs
JohanPlukon
SAML SSO with adfs
Is it possible to first, enable sso and still use the current users  that allready have been created as administrator?
And second, is there a manual how to configure SAML SSO with Microsoft ADFS?
JohanPlukon
Appeared you had to type the string manualy instead of copy pasting it.
JohanPlukon
JasonCampbell
Correct, you can still use and create regular org administrators. It's actually recommended to have at least 1 org admin outside of SSO in case of any SSO issues.
JohanPlukon
Ok thanks.
Did somebody also experience the below problem:
- SAML certificate fingerprint is invalid. It should be a colon-delimited hex string.
- Saml idps is invalid
I know for sure the fingerprint is correct, it's in capital letters and seperated by colon.
JohanPlukon
