I am testing AnyConnect and got the authentication part working well (SAML). But now I am wondering about the user experience and the AnyConnect client popping up anytime there is a change in connectivity with my wifi or ethernet connection. For example, I am in the office right now and anytime I stepped away from my desk long enough and I come back, the AnyConnect client is open with the "You may need to use a browser to gain access". Interestingly enough, my laptop is plugged in with power and set to not go to sleep. I suspect power saving changes made by Microsoft in the last few years are more aggressive and some devices go to "sleep". AnyConnect picks up on it and pops up. While this might be a small annoyance (just close it), I know my users are going to complain a lot.
I thought I just needed to disable the Disable Captive Portal Detection option and I already did that. And this is what I have in my profile file:
<DisableCaptivePortalDetection UserControllable="false">true</DisableCaptivePortalDetection>
Other options I have currently configured in my profile file that might be relevant (or not):
<AutoConnectOnStart UserControllable="false">false</AutoConnectOnStart>
<MinimizeOnConnect UserControllable="true">true</MinimizeOnConnect>
<AutoReconnect UserControllable="false">false</AutoReconnect>
<SuspendOnConnectedStandby>false</SuspendOnConnectedStandby>
<AutoUpdate UserControllable="false">true</AutoUpdate>
<AutomaticVPNPolicy>true
<TrustedDNSDomains>my_domain_here</TrustedDNSDomains>
<TrustedNetworkPolicy>Disconnect</TrustedNetworkPolicy>
<UntrustedNetworkPolicy>DoNothing</UntrustedNetworkPolicy>
<AlwaysOn>false
</AlwaysOn>
</AutomaticVPNPolicy>
