Challenges in Double WAN Redundancy Failover Test with Inter-VLAN Communication
Wikham
I opted to conduct failover testing by implementing double WAN redundancy. Instead of utilizing trunk ports, I tried using access ports for VLAN 10,20 with a trunk on the Link Aggregation Group (LAG) between the switches.
Equipment:
2x MS390
2x MX68
TEST1:
The failover process worked seamlessly when I removed the WAN 1 cable from the primary firewall, successfully transitioning to WAN 2 on MX1.
TEST2:
Upon removing the cable from VLAN 10, the expected behavior was for the MX to failover to its spare unit. However, this did not occur, despite the fact that VRRP messages were supposed to be continuously exchanged between the MX devices.
Has anyone else ever tested this, and if so, were they able to observe similar results or encountered different outcomes?
Thanks!
KH
Meraki Employee All-Star
The wording can be kind of confusing, it means any VLAN in the context that no VLAN at all is seeing VRRP Packets, not that when any VLAN doesn't show VRRP packets it fails over. I have actually just updated this KB article so that it is more clear to say: "When no advertisements reach the spare on all VLANs, it will trigger a failover"
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
6 Replies 6
KH
VRRP Packets are sent across all VLANs, so you still have the MXes receiving VRRP Packets on VLAN 20 and they think all is well.
RaphaelL
LAN failover: The two appliances share health information over the network via the VRRP protocol. These VRRP heartbeats occur at layer two and are performed on all configured VLANs. If no advertisements reach the spare on any VLAN, it will trigger a failover. When the warm spare begins receiving VRRP heartbeats again, it will relinquish the active role back to the primary appliance.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
I thought that if VRRP sent on vlan 10 weren't received by MX 'B' , it would create a dual active , since the MX 'B' thinks MX 'A' is gone.
KH
RaphaelL
Ahhhh got it !
Indeed , I'm not a native english speaker , so that confused me ! Thanks for the clarification 🙂
Wikham
Thanks for clearing this out!
DanielWahlsten
Wiktor for president!
