Hoping someone else has encountered this and can offer some guidance.
I have a client that has two organizations.  Org 1 has their MX's which is managed by their ISP.  Org 2 has all of their other Meraki gear (switches, AP's, mobile gateway etc..)
Org 1 uses per device licensing
Org 2 uses co-term licensing
The client is looking to eventually move away from the ISP managing their firewalls because they really are not providing any management anyways.
The client is setting up a new location so is looking to introduce a 3rd firewall.  Since they are looking to migrate away from their ISP for management, the idea was to put the new MX in org 2 and establish a non-meraki VPN peer to the other two sites.
According to support, failover is not supported on non-meraki.   So I guess that means the option to use FQDN with version 18.1 or later is JUST for clients with DHCP.  This client has two MX100's in active/standby at both locations in org 1.
So given this information, our next idea was to accept this risk of not having the 3rd site form a VPN tunnel on our backup WAN and once the contract is up with the ISP we could then pull in and license the MX100's in org 2 and use Auto-VPN.
Problem is, it looks like the non-meraki peer configuration is organizational wide.   So I can only get the VPN to pin up to one network or the other within Org 1 from Org2. I'm not sure why it would ever be an organization wide setting - it should be a network wide setting right???
So I think the only way to solve this is to move the device from org2 (co-term) to org1 (per device) and use the auto-vpn feature.  Then when the contract is up with the ISP, move the device and licensing back under org2.
Just wanted to check with the community to make sure I wasn't missing a simple fix here.
Thanks!
