I'm hoping to get some info on deploying an MX67C in the UK.
Right now, I have 120+ MX67Cs deployed throughout the US and each one has a Verizon SIM card in it. I've been told that Verizon isn't "certified" to work with these devices and there has been some headaches from time to time because of that. It's been suggested a few times that I switch to AT&T (this is a setup that was in before my time so it's an uphill battle to do that).
That said, we're looking to expand our work into the UK and that means deploying MX67Cs with LTE. Which service is recommended for these? Do I need to purchase a special license/edition of the MX67C to use it in the UK? Is there anything I should be aware of that's different or notable between the US and UK?
@movingonup : well i think you need to check the ISP supported for SIM cards there in UK. Below are the vendors supported worldwide, For UK i think BT and Orange is supported.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
