802.1x on MX Ports
MichelRueger
802.1x on MX Ports
Hi Meraki Gugus,
In the past it was possible to configure 802.1x or MAC authentication on MX ports. See Link .This option is not anymore possible in the Dashboard. Does Anybody know how to do it now?
Thanks for any Help.
Michel
13 Replies 13
kYutobi
Security & SD-WAN / Access Control
Enthusiast
MichelRueger
Hi All,
Thanks for all this replays. It seem to be a bigger Problem. I will ask this to my Swiss Meraki Engeneer.
BrechtSchamp
Yeah that was an annoying caveat I only found out recently. I still don't understand why it isn't there. Seems like a software thing to me...
Nash
Maybe bringing it in line with other models? I don't know. Just realized 64s, 65s, and Zs were the only things that ever supported it.
BrechtSchamp
Well it should be supported in 68 too. I mean, the 68cw is practically designed to be used as a branch in a box solution. So endpoints will connect to it directly. And they will likely be very accessible too in that case. So .1x makes a lot of sense.
SoCalRacer
Which MX are you trying this on?
currently stil only on mx 64 and 65 models. port has to be set to access
SoCalRacer
MX68 and 802.1x
There is the thread. I opened a ticket with support then and confirmed not available on all 67 or 68 devices with 15.13. Might be different now that 15.15 is available, but none of the release notes indicate that.
RaphaelL
MX67-68 still don't support .1X with the latest Beta software and doesn't seem to be in their roadmap either.
Nash
@RaphaelL interesting. Have you heard anything about why it's not on the map, or is this gut feeling?
Mango
I would love to know if this is ever supposed to be available on the MX67/68. I would also wonder why was it left off in the first place?
MichelRueger
Hi all,
I just got thee information from a Meraki Guru that the MX67 and MX68 will get 802.1x soon true a software update.
So lets wait and see 🙂
DavidWitt
There appear to be a couple threads on this so I'm cross posting.  Here is a post I made recently about the latest beta firmware update that seems to restore this feature.
https://community.meraki.com/t5/Security-SD-WAN/MX68-and-802-1x/m-p/73423/highlight/true#M18391
